Store Network Diagram Failed
949
02-29-2024 03:03 AM
IDT_tinghuahuang
After tracing, i creat a basic diagram.
And i tried to store the diagram.
The GPtool works successfully, and the diagram shows in catalog.
But i can't use the Find Diagram in Utility Network tab to find the diagram.
And if i close the Diagram map, it will also disappear in catalog like it's still temporary.
Using ArcGIS Pro 3.1 the Utility Network is build in file geodatabase.
IDT_tinghuahuang
Well it turns out causing by wield ArcGIS Pro schema lock.
It's one of my map not function correctly.
The diagrem store is successed but it just not read properly.
I close the map and read my Utility Network again and problem solved.
IDT_tinghuahuang
