Representing multiple service meters connected to a single service line
1328
05-06-2025 07:38 AM
Letíciad_Agosto_Miguel_Fonseca
Good day, everyone.
We are configuring a Water and Sewer Utility Network for a Brazilian customer with the following requirements:
  1. Representing multiple geographically represented service meters connected to a single service line (standard in this region).
  2. Selecting these service meters during a trace for further analysis.
Has anyone else modeled this scenario in a Utility Network? We would appreciate any best practices you can share.
Conceptually, the visual model includes a connection point or device (indicated by the orange point) at the service line termination, serving as the attachment for multiple geographically represented service meters.
Letciad_Agosto_Miguel_Fonseca_1-1746542208781.pngLetciad_Agosto_Miguel_Fonseca_1-1746542208781.png
Thanks for any input!
MikeMillerGIS
Esri Frequent Contributor
You can terminate the Service line with a service connection and then create an association to a meter or skip the service connection and add three more service lines from the end of a main service line to each meter.
MikeMillerGIS
PierreloupDucroix
MVP Regular Contributor
We modeled a pretty similar scenario where we have a primary service meter connected to several secondary meters (the case of a building). We have two different asset types and each secondary meter is connected to the primary meter with a connectivity association. This way, you can use output parameters to select primary or secondary meters in your trace and subnetwork configuration.
CEO of MAGIS
Thanks everyone!
