Query Syntax for Condition Barriers in Tier Definition
206
07-03-2026 07:28 AM
Rohanrajan
arcpy.un.SetSubnetworkDefinition(
in_utility_network=r"",
domain_network="Water",
tier_name="Pressure Boundary",
support_disjoint_subnetwork="SUPPORT_DISJOINT",
valid_devices="Telemetry/Unknown;Telemetry/ClearWell;Telemetry/Tank;Telemetry/StandPipe;Telemetry/PumpStation;Telemetry/MeterStation;Telemetry/PressureRecorder;Telemetry/MotorizedValve;Hydrant/Unknown;Hydrant/Hydrant;Valve/Unknown;Valve/AirRelease;Valve/Altitude;Valve/BlowOff;Valve/Butterfly;Valve/Check;Valve/Gate;Valve/LevelControl;Valve/PostIndicator;Valve/PressureRegulator;Valve/RPZ;Valve/Pito;Valve/FireService_Val;Valve/PressureBoundary;Valve/Stub_Val;Valve/Abandoned_Open;Valve/Abandoned_Closed;Meters/Unknown;Meters/Meters",
valid_subnetwork_controller="Telemetry/PumpStation;Valve/Gate;Valve/PressureRegulator",
valid_lines="HydrantLead/Unknown;HydrantLead/HydrantLead;Laterals/Unknown;Laterals/Laterals;Main/Distribution;Main/FireService_Lead;Main/Stub;'Main/Wash Water';'Main/Settled Water';'Main/Filtered Water'",
aggregated_line="Main/Distribution;Main/FireService_Lead;Main/Stub;'Main/Wash Water';'Main/Settled Water';'Main/Filtered Water'",
diagram_template=None,
summaries=None,
condition_barriers="ValveStatus IS_EQUAL_TO SPECIFIC_VALUE 2 AND;'Asset group' IS_EQUAL_TO SPECIFIC_VALUE 3 AND;'Asset type' INCLUDES_THE_VALUES SPECIFIC_VALUE (3,6,7,10,11) #",
function_barriers=None,
include_barriers="INCLUDE_BARRIERS",
traversability_scope="BOTH_JUNCTIONS_AND_EDGES",
propagators=None,
update_structure_features="UPDATE",
update_container_features="UPDATE",
edit_mode_for_default_version="WITHOUT_EVENTING",
edit_mode_for_named_version="WITHOUT_EVENTING",
valid_junctions="Fitting/Unknown;Fitting/Bend;Fitting/Cross;Fitting/EndOfMain;Fitting/Tee;Fitting/Plug;Fitting/Reducer;Fitting/Sleeve;'Fitting/Plugged Tee';Fitting/Increaser;Fitting/Coupling;PipeHop/Unknown;PipeHop/PipeHop;Water_Net_Junctions/Water_Net_Junctions;MeterBox/Unknown;MeterBox/MeterBox",
valid_junction_objects=None,
valid_junction_object_subnetwork_controller=None,
valid_edge_objects=None,
manage_subnetwork_isdirty="NOT_MANAGE",
include_containers="INCLUDE_CONTAINERS",
include_content="INCLUDE_CONTENT",
include_structures="INCLUDE_STRUCTURES",
validate_locatability="DO_NOT_VALIDATE_LOCATABILITY"
does this condition work like ValveStatus == 2 AND AssetGroup == 3 AND AssetType IN (3,6,7,10,11)
Any advice on this is much appreciated.
Thanks in advance
RobertKrisher
First
Instead of directly referencing asset groups or types in your subnetwork definition you should strongly consider creating a new network category, assigning it to the asset types, and referencing that in your subnetwork definition/traces. This makes it easier to maintain your subnetwork definitions (and trace configurations) without needing to memorize all the code.
Second
It should. You can always test it out by running the python in pro then opening the tool in your GP history. In this case I'd just swap out the condition barriers in the trace.
Third
Is that really what you want? You only want to treat certain types of closed devices as barriers? A closed device should be treated as a barrier regardless of what type of equipment it is.
