Hello all the UN wonderer,
I have a few UN publishing question and hoping that this community can give me a hand on this.
1. What is the recommended way to publish UN? Is it by asset group, asset type or even subtype group layer? Coming across this post Understanding the Differences Between Utility Network Maps (esri.com) suggesting that it is advisable not to publish UNM by subtype group layer as this will cause some issue with domain and subtypes.
2. We have then published UNM by AssetType together with all the symbology, but it turns out that Asset group is displayed as code in Map Viewer. This happens to Feature layer (Utility Network). Anyone has any idea on what we should be checking at?
In Map Image Layer, asset group is able to displayed the description.
*Note: Using AE v11.1
@AmberY the blog that @rlyding is referring to is this one: https://community.esri.com/t5/arcgis-utility-network-blog/best-practices-for-working-with-utility-ne.... It discusses how the solutions team intended for users to publish their feature services and maps (asset groups in the feature service, symbology/subtype group layers in the web map/desktop map).
@ahargreaves_FW Its hard to say based on the screenshot, please reach out to support so they can take a look at what's going on.
