no subnetwork cntroller found and no starting point
512
11-24-2024 02:11 AM
abderhman97
I'm working with the water utility network after loading data I fixed all dirty areas and assigned a bulk meter as a subnetwork controller for the system tire but I faced an issue when I tried to run the update is connected tool the error no starting point returned and however I assigned a bulk meter as a subnetwork controller when I tried to run the  update subnetwork tool the error no valid subnetwork controller returned additionally I tried to run connected trace however I create start point the error now valid start point returned, what are the potential reasons for this case
