Load Data Using Workspace on rest service
1048
07-02-2025 01:15 AM
gpgisandsky
Im using the tools Load Data Using Workspace directly on rest service putting the url of  layer (like this https://mygis.map.com/arcgis/rest/services/UN/MyUtilityNetwork/FeatureServer/1 ) in field target of DataReference.xlsx
The loading of data work fine but the data are imported on default version. is there a way/parameter to import the data specify another version?
thank you
2 Solutions
TedHoward2
Loading data to a branch version is not supported in the Data Loading toolset. It's a good question though and it has come up before. I'll make note of this in our backlog.
TedHoward2
Hello @gpgisandsky, I wanted to let you know we have enabled this in the Pro 3.7 release. It would require manually updating the path to your branch version in the DataReference workbook with the following syntax:
FeatureServerURL;VERSION=VERSIONNAME/LAYERID
Example:
https://example.esri.com/server/rest/services/ExampleService/FeatureServer;[email protected]_name/3
TedHoward2
gpgisandsky
hi Ted,
thank you for your replay and to make note in your backlog. Please, let's me know where there are some news.
gpgisandsky
Hi @TedHoward2, are there good news?
TedHoward2
Example:
gpgisandsky
Hi@TedHoward2 excellent! this is a good news! thank you!
