Legacy Data - How to handle in UN
1088
03-02-2021 10:41 AM
TJ_Houle
Hi everyone-
We are migrating a pretty large gas data set to the UN. We have a situation where we have certain legacy data that is a part of the existing GIS, but we don't want it to necessarily have the same rules as newer data?
For a quick example, an existing plastic to plastic connection is valid, but we don't want users to be able to add a new one.
Does anyone have ideas on how we could implement this?
  • Lifecycle status?
  • Minimal connectivity rules with very explicit attribute rules?
Any thoughts or pervious experience would be very helpful!!
she/her/hers
MikeMillerGIS
Esri Frequent Contributor
Best option is an attribute rule to restrict the edit. This rule would be disabled when the data is loaded and then enabled once editing has started.
I do not have a rules that meets your needs prebuild, but an example of a constraint here can be found here:
https://github.com/Esri/arcade-expressions/blob/master/attribute_rule_constraint/only_at_start_end.m...
