isolation tracing not show domain code at travesability
1560
03-03-2024 08:37 PM
NadiaAlami
Hi everyone, we try to run isolation tracing, however when to choose the value, the code domain not available as shown below, i need to key in the code.
But, for  lifecycle status, the domain shown
 we already set the domain when create the network attribute
What should we do..
thank you..
3 Solutions
MikeMillerGIS
Esri Frequent Contributor
Sadly, it does not use the domain of the inline network attribute.  It uses the domain assigned at the field of the first class that NA is assigned to.
RobertKrisher
@NadiaAlami Make sure that your device class has the correct domain assigned to it at the object class level (for this UI), and that each subtype/asset group that corresponds to an operable device has this domain assigned at the subtype level (for the attribute editor).
NadiaAlami
Hi MikeMillerGIS, thank you so much, i understand and manage to solve it.
MikeMillerGIS
NadiaAlami
RobertKrisher
NadiaAlami
Hi RobertKrisher.
Yes i assign the domain  and manage to solve the problem.
Thank you so much for your help.
