Hi, I am trying to go through the tasks coming together with the water solution. Following error poped up at the Isolate Leak task. When I open the Water Isolation Trace tool from toolbox and there is still an error. Please kindly help.
The software environment is ArcgisPro2.7. The asset package model version is 4. arcpy is 2.7.
It looks like the task was incorrectly set to the wrong model, you can use the task designer to set it to the model in the Water Traces toolbox.
