Intersection of Two Traces
514
11-06-2025 08:56 AM
NathanHeickLACSD
Is it possible to create a trace configuration that finds the intersection of multiple upstream traces from multiple starting points?  Alternatively, do you have to perform multiple traces and intersect the results?
The use case I am trying to support is finding a blockage or change to a sewer system that could have created observed impacts at two different downstream locations.  It helps to speed up troubleshooting.
RobertKrisher
No, but this is something you could achieve through a Python script that compares the trace results of two separate traces.
RobertKrisher
