Import associations in Utility Network
4414
7
10-03-2023 02:41 PM
DeepikaJain01
Dear Team
I am new in building the Utility Network. I have applied Asset Package and have built the UN from the foundation solution. The issue is it has not imported the associations, the "Association Status" field is null for all my Feature classes. Can you please help me as to how can I update the associations for all the Communication and Structure Feature classes.
Thank You
RobertKrisher
@DeepikaJain01 oh, that's your problem. You need to create all the objects in the asset package and populate the C_Assocations table with the foreign keys and other information in order to relate the objects. Setting the association status of a feature to be a container isn't sufficient, as it doesn't tell the system which features should be used as its content.
The bug that Pierreloup described means that after you apply your asset package (with all your associations) that the associationstatus field will be out of sync.
RobertKrisher
The association status field is a system- maintained field that will be populated automatically based on the types of associations present for a feature.
When you say that there weren't any associations imported, were there any errors during the apply asset package process? Did you populate the C_Associations table in the asset package ahead of time? Are there any errors associated with your associations?
DeepikaJain01
Hi @RobertKrisher
There were no errors when I applied the asset package, I am not sure what has caused the issue. Let me reapply the asset package and see if associations get imported. Also, I didnot populate C_Associations table in Asset package. I thought defining the Association status in asset package in the feature classes is sufficient.
RobertKrisher
PierreloupDucroix
MVP Regular Contributor
there is a bug where you need to import associations after enabling the topology, because the Association status is not calculated if you import before anebling topo.
Maybe you can check that first.
CEO of MAGIS
NSimmons44
I was not able to find this bug logged anywhere, but wondering is there another resolution or way around this issue? Loading all of the data into the asset package is not an option for us at this point. We are applying asset package, then loading all data. We have tried importing associations both before and after enabling topology, but haven't gotten the association status field to update correct for all features. However, even though the association status doesn't always update, the associations still exist, as shown in the image below.
The status seems to only sometimes get updated for structural attachments, but containment seems to be correctly updating for all relevant features.
@RobertKrisher do you have any other ideas or workarounds for this issue?
RobertKrisher
@NSimmons44 I recommend you log a support case on this. They will be able to help you with identifying any known issues and workarounds.
jhd011
I confirmed the same issue on my end. What were your findings and/or resolution from the support case?
