Import annotation from Geometric Network to utility network
861
03-15-2023 09:30 AM
PWPAdmin
Does anyone know if there is a way/method/tool that allows us to import our feature-linked annotation from GN to UN as a new annotation feature?
egcon27
Did you ever figure this out? I have the same question. @RobertKrisher
RobertKrisher
It is possible, but it depends on how you're doing your data migration. As an example, if you're using the Migration toolset to migrate your data over, and your feature-linked annotation is related via a global id, we can bring the data over as related data during the migration.
Other tools and methods can be used, but the biggest challenge is ensuring you're properly creating the consolidated annotation class in the target environment before you migrate the feature-linked annotation to the new database. That's not to say that the process is easy, but it is possible, and most data conversion vendors have cretaed special tools and processes already established to prepare, validate, and migrate feature-linked annotation.
If you have any broken or invalid annotation in your source data, you will need to get that cleaned up first.
