How to migrate from geometric network into utility network
5529
06-03-2023 06:27 PM
spiderman90
Hello ,
i would like to migrate the geometric network from arcmap to utility network
but I am not sure where could I start ?
i habe read that FME could help or by tools from ArcGis pro
could someone advice me ,where should I start to migrating ? What should I do ?
robertopepato_bizpoke
Hi @spiderman90 ,
I believe that Esri data loading tools is the easiest way for you to start. You can find it here: https://solutions.arcgis.com/shared/help/data-loading/
You can also find a lab on how to work with dlttools that can help you get started. It is available here: https://learn.arcgis.com/en/projects/load-data-into-the-arcgis-utility-network/
However, keep in mind that implementing UN, especially for production scenarios, is not a trivial migration. Depending on the organization's needs, the organization's expected business outcomes, the quality of your organization's existing data, its existing data models, and some other factors, migration can vary from medium to big effort. If you have a chance to evaluate consultancy support for this initial implementation, I'd recommend trying it.
Best
Hi @spiderman90 ,
Best
spiderman90
@robertopepato_bizpoke
I will read about data loading tools . K
could u please tell me from ur experience ,the steps that u did for doing ?
is there good article to explain all steps  to change from geometric network into utility network ?
I found the following videos from Esri Events  that may be helpful with concepts and technical guidance:
https://www.youtube.com/watch?v=HLQc0WHJiaw
https://www.youtube.com/watch?v=cudpvQGiOnM
Please, keep in mind that one of the recordings is from 5 years ago and UN may had some significant changes since then.
@spiderman90 Something else that may be valuable to you (if you haven't tried it yet) to get a sense of the UN, and its deployment/data loading stages in the electric domain, is implementing the Electric Utility Network Foundation. You can find it here if you get interested: https://www.arcgis.com/apps/solutions/index.html?gallery=true&solution=5ito8rwshywjd9qen5ka8nixgth3z...
spiderman90
Thanks a lot .I wad looking for it today .
i will work on it and if I have question , I will ask you .i appreciate really ur help .
