How can I Register Dataset ? (Error 002764)
6893
10
03-28-2021 01:58 AM
GIS_Solutions
Hi everyone,
I have 2 datasets in the same database, Utility Network is installed in one of them (dataset name Elektrik), in the other the UN is not installed.
I can not register the dataset installed in the utility network. I cannot pass the attached error message, what should I do.
I have
ArcGIS Pro 2.6
SQL Server 2016
ArcGIS Enterprise 10.8.1
Utility Network Version 4
JonDeRose
@GIS_Solutions Just to add to what Dan said, while traditional versioning is not supported by some datasets (such as the utility networks and parcel fabrics), this does not prevent you from using both to support your workflows.  You can use branch for the utility network while also registering data that is not part of the network using traditional versioning to edit in ArcGIS Pro via database connection.  This topic provides some additional information into management strategies such as this:  https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/data-management-strategies....
