Experience Builder 11.5 ExB issues with trace widget and table widget
576
11
08-14-2025 07:03 AM
gis_KIWI4
We have recently upgraded to 11.5 and from what I can see we have 2 open issues (possibly connected)
Scenario 1 - Run a trace. Select a bunch of Low Voltage Service in the table widget. Export CSV.
Data is missing.
Export it again, it seems to work.
Scenario 2 - The "Run" button on the trace widget is missing and a quick refresh seems to fix it.
I have checked the logs on the server and nothing notable.
@AlixVezina
PierreloupDucroix
I've already opened a case a few months ago for your first issue, it was also present un 11.3 and Esri support reproduced in 11.5
BUG-000177756
CEO of MAGIS
gis_KIWI4
@PierreloupDucroix  - Thanks! I tried searching this on the support website and I couldn't find the bug.
The thing is were used to have 11.3 and it worked perfectly well for us then.
It's only changed after moving to 11.5
PierreloupDucroix
I didn't specify, but the bug was in version 1.15 of Experience Builder Developer Edition, used with AGE 11.3.
Also reproduced by the support team in ExB 1.17 Dev Edition, which is also the default version in AGE 11.5.
CEO of MAGIS
PierreloupDucroix
Bug is still in review
CEO of MAGIS
AlixVezina
Hi @gis_KIWI4 @PierreloupDucroix ,
Is the Table widget connected to the layers in the map (Interact with a Map widget), or connected to specific individual layers and using a specific data view (e.g., Selected features)?
Is your data rendered in the map using Subtype Group Layers?
Thank you!
PierreloupDucroix
Hi Alix,
yes, the table widget is connected to the layers in the map with the "interact with a map widget" option.
The map was created in Pro with subtype group layers and shared to the portal.
CEO of MAGIS
AlixVezina
Thank you! I am able to reproduce the issue on my end as well. We are looking into it.
gis_KIWI4
Thanks for looking into this @AlixVezina .
I have encountered the issue on both maps with subtype group layers and traditional layers.
gis_KIWI4
@AlixVezina - The Scenario 2 in my question where the "Run" button on the trace disappears. We have been able to replicate it.
The best I can describe it is - The run button does not show up on the trace widget if you change layer visibility within the layers widget before launching the Trace Widget.
Here is a video of it in action.
Conversely if I launch the UN Trace widget first then the "Run" button is visible and subsequent toggling of layer visibility does not  cause the "Run" button to disappear.
Tried this removing the trace widget out of the Widget Controller. Same behavior.
Tried this with subtype and conventional layer maps. Same behavior.
