Esri has any multispeak tools that could be integrated with Utility Network
1718
08-28-2023 08:55 AM
skarri
Hi
We are looking for any multispeak tools that could be integrated with Utility Network (11.1)/ArcPro 3.1 and be able to export serialized transformers (XML) from UN to NISC IVue or other applications.
Electricity model
Solved: Is the ArcGIS Utility Network compatible with CIM ... - Esri Community
RobertKrisher
The same answer for CIM applies to multispeak exports in that the Utility Network supports exporting its definition to JSON but customers, partners, and vendors need to create the tool to translate that JSON into whatever format they're using. If you're considering doing this yourself, I recommend you read the following article that explains how to parse Utility Network JSON files and includes a sample parser to get you started.
RobertKrisher
