Error Viewing Published UN Services
956
06-08-2022 02:06 PM
TSmith
Good Afternoon,
I am curious to see if anyone else has encountered an error similar to this one:
The DBMS table exists... as un_owner.UN_143_Associations. I can publish from SDE without any problems, but then this keeps happening.
I am on 10.9.1, utility network user type extension, signed into portal and the DB connection references the UN owner. Not sure what I'm doing wrong. So, portal and server show the service, but when I go to details, there's no layer list, etc.
The enterprise geodatabase functions as expected in ArcGIS Pro, and was created from a file geodatabase asset package via copy/paste.
This is what the UN Associations table looks like in SQL:
Any help would be greatly appreciated! 🙂
RobertKrisher
If you haven't already, I'd recommend logging a case with support on this.
