ERROR: Staging Failed (Unable to posting latest UPDM data to AGOL)
1827
5
01-10-2024 05:24 AM
neomapper
Why is it so difficult to copy data from the latest UPDM to ArcGIS Online? I've tried publishing multiple different ways from ArcGIS Pro and nothing seems to work. We are using the latest UPDM published on the solutions page and the database was loaded in SQL 2019.  I'll post the errors I keep receiving. Any help would be appreciated!
ERROR:
Pipeline Devices 41 WebVectorTileLayer Hearthstone Utilities Inc. https://www.arcgis.com/ neomapper1 2024-01-10 08:08:29 Status: InProgress StatusMessage: Successfully wrote sharing info file
Pipeline Devices 41 WebVectorTileLayer Hearthstone Utilities Inc. https://www.arcgis.com/ neomapper1 2024-01-10 08:08:29 Status: InProgress StatusMessage: Successfully wrote sharing connection file (Number of SDE Connections: 1)
Pipeline Devices 41 WebVectorTileLayer Hearthstone Utilities Inc. https://www.arcgis.com/ neomapper1 2024-01-10 08:08:29 Status: InProgress StatusMessage: Loading manifest
Pipeline Devices 41 WebVectorTileLayer Hearthstone Utilities Inc. https://www.arcgis.com/ neomapper1 2024-01-10 08:08:29 Status: InProgress StatusMessage: Creating thumbnail from map
Pipeline Devices 41 WebVectorTileLayer Hearthstone Utilities Inc. https://www.arcgis.com/ neomapper1 2024-01-10 08:08:30 Status: Pending StatusMessage: Sharing process started
Pipeline Devices 41 WebVectorTileLayer Hearthstone Utilities Inc. https://www.arcgis.com/ neomapper1 2024-01-10 08:08:30 Status: InProgress StatusMessage: Sharing process started
Pipeline Devices 41 WebVectorTileLayer Hearthstone Utilities Inc. https://www.arcgis.com/ neomapper1 2024-01-10 08:08:30 Status: InProgress StatusMessage: Loading manifest
Pipeline Devices 41 WebVectorTileLayer Hearthstone Utilities Inc. https://www.arcgis.com/ neomapper1 2024-01-10 08:08:30 Status: InProgress StatusMessage: Reading thumbnail from file
Pipeline Devices 41 WebVectorTileLayer Hearthstone Utilities Inc. https://www.arcgis.com/ neomapper1 2024-01-10 08:08:31 Status: InProgress StatusMessage: Publishing process started
Pipeline Devices 41 WebVectorTileLayer Hearthstone Utilities Inc. https://www.arcgis.com/ neomapper1 2024-01-10 08:08:31 Status: InProgress StatusMessage: Consolidating data and staging web layer
Pipeline Devices 41 WebVectorTileLayer Hearthstone Utilities Inc. https://www.arcgis.com/ neomapper1 2024-01-10 08:08:33 Status: InProgress StatusMessage: Loaded SDE Workspaces
Pipeline_Devices 41 WebVectorTileLayer Hearthstone Utilities Inc. https://www.arcgis.com/ neomapper1 2024-01-10 08:08:37 Status: InProgress StatusMessage: Using ArcGIS Version 13.2 for staging (Source for version: GP Staging Parameters)
Pipeline_Devices 41 WebVectorTileLayer Hearthstone Utilities Inc. https://www.arcgis.com/ neomapper1 2024-01-10 08:08:37 Status: InProgress StatusMessage: Stage Tool initialized
Pipeline_Devices 41 WebVectorTileLayer Hearthstone Utilities Inc. https://www.arcgis.com/ neomapper1 2024-01-10 08:08:37 Status: InProgress StatusMessage: Preparing maps and layers for processing
Pipeline_Devices 41 WebVectorTileLayer Hearthstone Utilities Inc. https://www.arcgis.com/ neomapper1 2024-01-10 08:08:39 Status: InProgress StatusMessage: Consolidate data
Pipeline_Devices 41 WebVectorTileLayer Hearthstone Utilities Inc. https://www.arcgis.com/ neomapper1 2024-01-10 08:08:39 Status: InProgress StatusMessage: Staging feature service
Pipeline_Devices 41 WebVectorTileLayer Hearthstone Utilities Inc. https://www.arcgis.com/ neomapper1 2024-01-10 08:18:15 Status: Failed ErrorMessage: Consolidation failed
Pipeline Devices 41 WebVectorTileLayer Hearthstone Utilities Inc. https://www.arcgis.com/ neomapper1 2024-01-10 08:18:15 Status: Failed ErrorMessage: ERROR 000260: DBMS table not found [DBMS table not found] [SDE.UN_6_DirtyAreas]--The dataset name is invalid. [Network]--The dataset name is invalid. [Network]--The dataset name is invalid. [Network]--The dataset name is invalid. [Network]
Pipeline Devices 41 WebVectorTileLayer Hearthstone Utilities Inc. https://www.arcgis.com/ neomapper1 2024-01-10 08:18:15 Status: Failed ErrorMessage: Failed to execute (StageService).
Pipeline Devices 41 WebVectorTileLayer Hearthstone Utilities Inc. https://www.arcgis.com/ neomapper1 2024-01-10 08:18:17 Status: Failed ErrorMessage: Staging failed
MikeMillerGIS
Esri Frequent Contributor
What settings are you selecting when you publish?  It looks like you selected Vector Tile, you want to check Map Image/Feature
neomapper
I don't seem to have Map Image > Feature option. When I open the share option all I see is Feature; which also doesn't work and will generate the same error.
MikeMillerGIS
You need to publish it to ArcGIS Enterprise.  Publishing to ArcGIS Online will copy the data into ArcGIS Online and out of your SQL Server DB.  Is this what you want to do?
neomapper
Hey Mike,
We use ArcGIS Online maps for viewing assets in the field. We don't use Enterprise for this use so it's paramount to be able to post updates using the new UPDM data model that we switched to.
Jordan
MikeMillerGIS
It looks like it is trying to publish the dirty area table, which I would say is a bug.  Best thing to do it delete the UtilityNetwork, since ArcGIS Online does not support the Utility Network
