Error 160222 Tracing the network - The network feature does not have an associated network element
1057
7
04-17-2026 09:07 AM
lorenzoz
Hello everyone,
I’m struggling with a persistent error while running a Trace in a Utility Network. Error 160222: https://pro.arcgis.com/en/pro-app/latest/tool-reference/tool-errors-and-warnings/160001-170000/tool-.... I see it's a rare error and there's not a single solution, so I provided a feedback and I hope this post can help.
I deployed the Utility Network using the Migrate To Utility Network tool with no initial errors. I’ve configured Tiers, Terminals, and Subnetworks, and assigned them to the appropriate devices. However, when I try to run a Trace, I consistently get the same error. I tried both Connected and Upstream/Downstream trace.
This is what I tried to solve the error:
I exported the Asset Package (with and without data) and redeployed it into a File Geodatabase (FGDB). The error persists even in a clean environment. I even tested with an empty deploy by creating and editing just a single line: same result.
The only clue I have is that, during a deployment via Asset Package to Geodatabase, I encountered an error stating "subnetwork field names cannot be nullable." Following this community thread, I deleted the problematic fields in the Asset Package and redeployed. The fields were recreated successfully, but the Trace error remains.
I feel like it's a schema inconsistency or a hidden data issue, but I'm running out of ideas since it happens even with a single feature. Has anyone encountered this specific behavior after a migration?
Any suggestions or insights would be greatly appreciated!
Thank you in advance,
Lorenzo
MikeMillerGIS
Esri Frequent Contributor
Could be related to the starting point layer being out of sync with the data.  In the projects home/default, delete the starting point and barrier classes.  Then re-add the starting point to the feature and give it a shot.
RobertKrisher
If you disable and re-enable the network topology, does that fix the error?
lorenzoz
It was the StartingPoint feature class. I deleted it and now it works!
MikeMillerGIS
lorenzoz
This solved the problem! Thank you very much! I deleted the feature classes in the home gdb and now it works! Thanks a lot
L
gis_KIWI4
MVP Regular Contributor
@lorenzoz - To troubleshoot this further, can you check the UN_Temp_tarting_Points layer in your Default Database. It should look something like this.
Can you confirm if the FEATUREGLOBALID matches the device/element you have selected?
lorenzoz
Deleting the Feature Class and re-adding it solved the problem!
MikeMillerGIS
Nice!  I have seen this and hoped it was the issue.  Essentially the information in the starting point layer is out of sync with the data.
