Error 160145 Load Data Using Workspace
1688
04-11-2025 12:30 PM
Yeaton
Hello,
I'm creating a utility network for a city sewer system.  I am using the simple data mapping and data migration tools because I want to preserve some of the source layer fields with attachments.  After data mapping I run the load data to preview tool without any problem.  When I run the load data to workspace tool, I get the following error: "ERROR 160145: The field is not nullable."
Looking through the fields of both the source and target data, I do not see anything wrong.  Referencing an earlier ESRI blog from a user having the same issue, an ESRI commentator said this may be a bug and to report it.
Thanks for any help
Best,
Aaron Y.
cpolley
Check your source data in the shape_length and make sure there is no NULL "empty values".
cpolley
Yeaton
Your recommendation worked! Thanks cpolley!
Best,
Aaron
cpolley
Your Welcome.
