ERROR 000732: Target Dataset: Dataset
2318
06-28-2024 08:22 AM
YulissaCamacho
Hi, I'm getting this error when I try to apply an Asset Package:
Failed to execute. Parameters are not valid.
ERROR 000732: Target Dataset: Dataset C:\Users\ycamacho\Documents\ArcGIS\Projects\MyProject1\CRGIS36.sde\Electric\StructureJunction does not exist or is not supported
Failed to execute (Append).
I tried to modify the subtypes of the feature that is in the error, but everytime I try to run the tool, the error change to a different feature in the dataset. So, I think there is somenthing wrong with the dataset.
However, I already applied the same AP with a different UN version and it passed clean.
I already tried to move the project to a different location to change the path but the error it's the same.
Any ideas?
Tags (1)
MikeMillerGIS
Esri Frequent Contributor
Do you have maps in the ArcGIS Pro project?  If so, try the process with a new ArcGIS Project with no maps.
YulissaCamacho
Thank you for the reply. But no, I get the same error
MikeMillerGIS
can you provide the entire message list from the GP tool?
YulissaCamacho
Sure:
Apply Asset Package
Parameters
Asset Package C:\Users\ycamacho\Documents\UtilityNetworkCG.gdb
Domain Networks to apply Structure;Electric
Input Utility Network C:\Users\ycamacho\Documents\ArcGIS\Projects\MyProject4\CRGIS36.sde\coopegis_completa_un5.utility.Electric\coopegis_completa_un5.utility.UtilityNetworkCG
Load data INCLUDE_DATA
Calculate Spatial Index and Analyze ANALYZE
Output Utility Network
Configurations to apply
Rename using
Post Process NO_POST_PROCESS
Messages
Start Time: Friday, June 28, 2024 10:39:23 AM
ArcGIS Pro 2.9.6.32739
untools 2.9.7
Executing from ArcGIS Pro, 0 map(s), activeMap = False
Parallel processing enabled: 6
Asset Package schema version: 2.9
Staging directory -- C:\Users\ycamacho\Documents\AP_Workspace15
2024-06-28 11:16:33 Starting 6 processes for Append
2024-06-28 11:17:03 Starting ElectricDevice...
2024-06-28 11:17:03 Start Time: Friday, June 28, 2024 11:16:59 AM
ERROR 000732: Target Dataset: Dataset C:\Users\ycamacho\Documents\ArcGIS\Projects\MyProject4\CRGIS36.sde\Electric\ElectricDevice does not exist or is not supported
Failed at Friday, June 28, 2024 11:17:00 AM (Elapsed Time: 0.03 seconds)
Failed to execute (AssetPackageToUtilityNetwork).
Failed at Friday, June 28, 2024 11:17:03 AM (Elapsed Time: 37 minutes 39 seconds)
PaulLeBlanc1
If you disable parallel processing in environment variables, does it still give the same error?
