enable utility network error
568
04-18-2025 09:21 AM
gpgisandsky
I deployed Utility Network v7 on ArcGIS Enterprise 11.3 (Oracle 19) with ArcGIS Pro 3.3.2.
When I try to enable the Utility Network topology directly on the .sde connection, it fails.
I also tried enabling the Utility Network topology through the service, but that fails as well.:
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Failed to execute (EnableNetworkTopology).
I also tried updating ArcGIS Pro from 3.3 to 3.5, but the operation still fails.
I also tried to excute repair geometry  but when I select xy Device from my project the following error appear:
Error 003341 This operation is not supported on Esri Spatial Types.
Has anyone experienced a similar issue?
