edge has invalid containers errors
1448
12-22-2024 03:23 PM
PierreloupDucroix
MVP Regular Contributor
Hello,
I have many errors in ArcGIS Server logs like :
UtilityNetworkQuery::get_Containers : edge has invalid containers, gdbname.username.ElectricLine({B0DEA525-076C-4FAB-98DB-6FF991E49004})
But looking at the feature in ArcGIS Pro, there is no error related to containment association (no dirty areas, no error in the attribute pane or in the modify association pane...)
The features are electric lines (cables) that are contained into structure points (cross-sections of ducts)
Do you what could cause these logs ?
CEO of MAGIS
PierreloupDucroix
I'm still constantly getting multiple warnings like this in my server logs.
@MikeMillerGIS : Any ideas what to check?
As far as I know, a structure point can contain an electric line, right ?
But can an electric line be contained into multiple structure points ? There is no information about this in the feature restriction documentation.
CEO of MAGIS
RobertKrisher
@PierreloupDucroix Structure junctions can contain edges, and an edge can belong to multiple containers. It's only point features that are limited to a single container. I've made a note to update our documentation about this.
Have you logged a case with support on this issue?
PierreloupDucroix
I wanted to clarify multiple containment restriction first.
I will log a case.
 Thanks
CEO of MAGIS
MikeMillerGIS
Esri Frequent Contributor
Def get the issue logged.  One note, if a line is contained in a point.  In diagram space, that line is collapse and with be completely in that container.  Just something to consider.  An attachment point on the line that is contained in that Structure Junction might be a better option if you are going to use diagrams.
PierreloupDucroix
I do use system diagrams on these subnetworks, but line appear correctly.
Maybe because I do not show the structure points in the diagrams
CEO of MAGIS
