I am working with a small-to-mid size Electric Distribution utility running UNM V5 and ArcGIS Enterprise 10.9.1. We have total ~500 HV subnetworks and ~30,000 LV subnetworks.
From time to time we need to disable network topology for UNM version upgrade, update topological rule etc. Every time we try to disable network topology, it takes really long time, between 3 hours to 10 hours. ArcGIS Pro machine is barely busy during this time and so is SQL Server 2022 where the UNM model is hosted.
We tracked SQL queries and it seems to inserting records in various tables such as ElectricSubnetLine, UN_xxxxx_SUBNETWORKS etc. Example below:
(@P1 smallint,@P2 nvarchar(255),@P3 datetime2,@P4 datetime2,@P5 int,@P6 int,@P7 datetime2,@P8 int)INSERT INTO SDO.ELECTRICSUBNETLINE (OBJECTID,SUBNETWORKNAME,TIERNAME,SUBNETWORKCONTROLLERNAMES,LASTUPDATESUBNETWORK,LASTACKEXPORTSUBNETWORK,SHAPE,GLOBALID,CreatedBy,CreationDate,ISDIRTY,LastUpdatedBy,LastUpdatedDate,GDB_GEOMATTR_DATA,GDB_FROM_DATE,GDB_BRANCH_ID) SELECT OBJECTID,SUBNETWORKNAME,TIERNAME,SUBNETWORKCONTROLLERNAMES,LASTUPDATESUBNETWORK,LASTACKEXPORTSUBNETWORK,SHAPE,GLOBALID,CreatedBy,CreationDate,@P1,@P2,@P3,GDB_GEOMATTR_DATA,@P4, @P5 FROM SDO.ELECTRICSUBNETLINE WHERE GDB_ARCHIVE_OID IN (SELECT GDB_ARCHIVE_OID FROM (SELECT GDB_ARCHIVE_OID ,ROW_NUMBER() OVER (PARTITION BY OBJECTID ORDER BY GDB_FROM_DATE DESC) rn,GDB_IS_DELETE FROM SDO.ELECTRICSUBNETLINE WITH (INDEX(gdb_ct1_1183)) WHERE OBJECTID= @P6 AND ((GDB_BRANCH_ID = 0 AND GDB_FROM_DATE <= @P7) OR GDB_BRANCH_ID = @P8)) MB_ WHERE rn = 1 AND GDB_IS_DELETE = 0) OPTION (MAXDOP 1)
SQL Server instance has not shown any stress while the disable tool is running. Is the time taken for disabling network topology expected to be that long (~10 hours)? How can we expedite this?
Vish
We have made several optimizations to how we handle disable network topology in the latest release to address this performance problem, and are planning on patching this according to the network management release plan. If you want to log a bug with support on the issue, they can take a look at whether something else is happening.
@RobertKrisher Good to know the issue is already addressed or being addressed. Can you please confirm which version this is applied to or will apply to? We just upgraded to AGE v11.5, the latest long term release.
@VishApte_NGIS, we plan to include the fixes in a patch to 11.5. If you log a case with support and get attached to the bug you can get notified when the specific patch releases.
