Deploy Electric Network Editor v3.4
1310
05-13-2021 03:32 PM
DLee
Hi!
I've successfully Staged, applied asset package, publish my network services but i can not deploy the solution using the ArcGIS Solutions.  When i try to deploy it, it does not ask for the data sources.  Any Ideas on how to fix this?
Thanks!
MikeMillerGIS
Esri Frequent Contributor
The workflow changed between 3.3 and 3.4
https://solutions.arcgis.com/electric/help/electric-utility-network-editor/get-started/release-notes...
March 2020 - Version 3.4
The March 2020 release of the Electric Utility Network Editor template version 3.4 includes the following updates:
  •    Deploy the network editor workflow has changed and a feature service is no longer required to deploy the solution.
https://solutions.arcgis.com/electric/help/electric-utility-network-editor/get-started/deploy-the-ne...
MikeMillerGIS
