Why does the newest Electric Unbalanced Distribution Utility Network Essentials download in the Electric Utility Network Foundation Solution no longer have a Data Dictionary Excel File?
The data dictionaries are now available directly in the help documentation.
@RobertKrisher - Can you please take a look at this?
Thank you @PatrickGCowan,
Is there any way to do filtering at the table level? We used the filtering functionality a lot in Excel.
For example: Filtering the Source Name on the Assignments Table. (see image)
We’re currently working on further enhancements to the online data dictionaries, including the addition of some filtering capabilities. At this time, the web-based version doesn’t support table-level filtering like Excel does.
If you prefer working in Excel, you can still generate your own version of the schema report using the following steps:
Tip: You can run this without loading data—you're just creating the schema.
