Data Dictionary Missing from Enterprise 11.5 UN Expanded Model (4.0)
747
10-02-2025 11:21 AM
Joshua_Moreno
Just downloaded the updated version of the Expanded Model 4.0 upon upgrade of our Enterprise Portal to 11.5 and noticed that the data dictionary XML and spreadsheet that usually comes with the previous models I have downloaded is missing. Didn't see any mention of it in the release notes.
PatrickGCowan
The data dictionaries are now hosted in the online help. For example, the electric data dictionary can be found here:
https://doc.arcgis.com/en/arcgis-solutions/latest/reference/introduction-to-electric-utility-network...
If you need to have an Excel format for the data dictionary you can use the Generate Schema Report geoprocessing tool to create one. Make sure to run it against a UN database (you can use the Asset Package to Geodatabase tool to create a UN database from the asset package).
It looks like that change was not included in the change log. We will get it added. Thanks for bringing that to our attention.
PatrickGCowan
Joshua_Moreno
Awesome, thank you so much!
