Creating a Utility Network creates a non unique index on globalid
1289
13
03-23-2026 10:05 PM
PierreloupDucroix
MVP Regular Contributor
After creating a Utility Network in an enterprise geodatabase, I noticed that an index had been created on both globalId and objectID fields, and that this index was not unique.
non-unique index in SDEnon-unique index in SDE
When loading data into feature classes, the "Preserve globalId" option generates error 003340.
I thought that, by design, any index on the globalID field should be unique. Could this be related to the archiving of the feature class? Is there a restriction on adding a unique identifier to this field?
For example, in a new UN created in a mobile geodatabase, there are two different unique indexes on the GID and OID fields.
Unique idx in mobile gdbUnique idx in mobile gdb
CEO of MAGIS
PierreloupDucroix
Of course, I meant "Append," not "Add".
After further testing, I'm now certain that enabling branch versioning and archiving is causing the incorrect index in the geodatabase:
I just tested in a new geodatabase, with a new schema and a new UN. Right after creating the UN (using the Stage Utility Network tool), the FCs have two unique indexes on the GID and the OID. But as soon as I enable branch versioning and archiving, the OID index is removed, and the other index now contain GID and OID fields and is no longer unique.
Tested with Pro 3.3.7 / AGE 11.3 but also seen with Pro 3.5.5 / AGE 11.5.
I am logging a case.
Thanks again for you help
CEO of MAGIS
RobertKrisher
@PierreloupDucroix index issue aside ... I had some issues getting the Append to work properly, until I read the doc more closely and realized that the Preserve Global ID option will only be respected on append (at the REST level) when defining a Matching Field, which places the tool in an Upsert Mode.
PierreloupDucroix
Oh, that's really interesting!
I also came across this REST documentation, but I wasn't sure if the append tool allowed updates via the REST API and in UPSERT mode.
Now I know it does, but I think the "Optimize performance for feature services" parameter is required in addition to a Matching Field on GID :
The Optimize performance for feature services parameter is only supported when the target dataset supports feature service append capabilities. When this parameter is checked, the following will be done:
  • The tool will use the ArcGIS REST API for optimal performance.
  • The Input Datasets parameter will be limited to one dataset.
  • The Expression and Enforce Domains parameters will not be supported.
  • The Matching Fields for Update parameter will be limited to one pair of matching fields.
  • The geometry of the target dataset will be updated by the geometry of the input dataset for matching rows.
  • All update and insert operations will be counted in the output Appended Row Count value.
I'm running tests to find out.
CEO of MAGIS
PierreloupDucroix
After several exchanges with Esri France support, it appears that the described behavior (non-unique index on two fields in a UN dataset) is indeed expected.
An internal Esri article, which I do not have access to, states:
Description:
When using the Append tool in ArcGIS Pro with the Preserve GlobalIDs environment setting set to true, the tool fails to function successfully and produces the following error:
ERROR 003340: The target dataset must have a GlobalID field with a unique index in order to use the Preserve GlobalIDs geoprocessing environment setting.
Cause:
This issue can occur when users attempt to run the Append tool on a dataset that is registered as branch versioned, such as a utility network. Datasets registered as branch versionned cannot have a unique index.
The only solution seems to be to use Python, or the method mentioned earlier: Optimize performance + globalId field mapping
CEO of MAGIS
