Create ServiceLines automatically?
1589
03-30-2022 07:12 AM
SergioOrdás
Hi everybody,
I just wonder if there is any way or any tool which helps me to create ServiceLines (Laterals) automatically within my UtilityNetwork. As fas as I remember, there was such a Tool in the previous Geometric Network fo ArcMap.
Some ideas about how to do it?
Thanks in advance!
MikeMillerGIS
Esri Frequent Contributor
We have played around doing this in Arcade and an attribute rule.
Here is the code if you want to try it out.
function find_closest_line() {
   var line_class = FeatureSetByName($datastore, "line", ["objectid"], true);
   //var candidates = Intersects(line_class, Buffer($feature, 500, "miles"));
   var candidates = line_class;
   var shortest = [1e10, null];
   for (var line in candidates) {
      var d = Distance($feature, line)
      if (d < shortest[0]) shortest = [d, line]
   return shortest[-1]
function point_and_distance(point_feature, other_feature) {
		finds the closest point from point_feature to other_feature
		Args:
			point_feature: Point Geometry
			other_feature: Point/Line/Polygon Geometry
		Returns: dictionary
			{distance: number,               // distance from point_feature to closest point
			 point: geometry,  // the coordinate pair of the closest point
			 isVertex: bool}                 // if the closest point is a vertex of other_feature
	var point_feature = Geometry(point_feature);
	var other_feature = Geometry(other_feature);
	var shape = TypeOf(other_feature);
	var vertices;
	if (shape == 'Point') {
		return {"distance": Distance(point_feature, other_feature),
		        "coordinates": [other_feature["x"], other_feature["y"]],
				"isVertex": true}
	else if (shape == 'Multipoint') {
	    var points = other_feature["points"];
	    for (var i in points) {
	       var p = points[i]
	       var dist = Distance(point_feature, p);
	       if (dist < shortest[0]) shortest = [dist, [p["x"], p["y"]]]
	    return {"distance": shortest[0],
		        "coordinates": shortest[1],
				"isVertex": true}
    else if (shape == 'Polyline') vertices = other_feature["paths"]
	else if (shape == 'Polygon') vertices = other_feature["rings"]
	else return null
	var x = point_feature["x"];
	var y = point_feature["y"];
	// Loop through each part of the geometry and each segment, tracking the shortest distance
	var shortest = [1e10];
	for (var i in vertices) {
	    var part = vertices[i];
	    var previous = part[0];
	    for (var j = 1; j < Count(part); j++) {
	        var current = part[j];
	        var result = pDistance(x, y, previous["x"], previous["y"], current["x"], current["y"]);
	        if (result[0] < shortest[0]) shortest = result
	        previous = current;
	// Couldn't find anything
	if (Count(shortest) == 1) return null
	        "isVertex": shortest[2]}
function pDistance(x, y, x1, y1, x2, y2) {
  // adopted from https://stackoverflow.com/a/6853926
  var A = x - x1;
  var B = y - y1;
  var C = x2 - x1;
  var D = y2 - y1;
  var dot = A * C + B * D;
  var len_sq = C * C + D * D;
  var param = -1;
  if (len_sq != 0) //in case of 0 length line
      param = dot / len_sq;
  var xx, yy;
  var is_vertex = true;
  if (param < 0) {
    xx = x1;
    yy = y1;
  else if (param > 1) {
    xx = x2;
    yy = y2;
  else {
    is_vertex = false;
    xx = x1 + param * C;
    yy = y1 + param * D;
  var dx = x - xx;
  var dy = y - yy;
  return [Sqrt(dx * dx + dy * dy), [xx, yy], is_vertex];
function create_line(start, end_coordinates) {
    var geo = Geometry(start);
    return Polyline({"paths": [[[geo["x"], geo["y"]], end_coordinates]], "spatialReference": geo["spatialReference"]})
var closest = find_closest_line();
if (closest == null) return null
var data = point_and_distance($feature, closest);
if (data == null) return null
var lateral = create_line($feature, data["coordinates"]);
return {"result": null,
        "edit": [{
            "className": "lateral", "adds": [{"geometry": lateral}]
SergioOrdás
Thanks for the answer Mike, I would like to have a more firendly user tool within the UN (as in the previous Geometric Network) but I will have to try it this way if no other option then.
Thanks for the code and I will write a feedback if I finally have to use it
SSMIC3038
I'll be trying that, I also really like those ArcMap tools Sergio mentions, thanks Mike.
