System Details: Pro3.1, water distribution foundation v1.3, coordinate system New Zealand Transverse Mercator, units: metres
I'm getting unexpected associations using B_Rules table and Create Association Records GP tool.
I have generated some test data inside a foundation water distribution asset package consisting of service connections and service meters. The service meters are offset from the connection points in distances from <1m, <5m and <10m.
In this attempt, I have nominated 1 as the "Distance for associations" in the B_Rules table. I would expect that only meters within 1 m of a service connection would have an association record generated.
Below is a screengrab of my B_Rules table, noting that there are only distances nominated for meter to service connection, and not meter to meter. The rest of the table's distance values are <Null>:
Below is a screengrab of my meters and service connections. Red circles are 1 m buffers around the service connections that I'm testing. Three meters are within a red circle and I expect them to have associations generated when I run the Create Association Records GP tool:
The tool runs successfully, but too many associations are generated. In addition to the three I expected (green circles), an additional four (red circles) were generated that connect meters with other meters:
One pattern I note is that meters that are not connected to anything are >5m away from the next device, otherwise this looks random.
To prevent the association records from being generated I was able to put in a distance of -1 for all the undesirable meter-to-meter connectivity (highlighted rows below):
Is this a bug? If not, can anyone point me towards additional documentation on how this distance field is supposed to work?
Thanks
Solved! Go to Solution.
The embedded tool help has the following info, which matches what you are seeing:
To define distance, add/populate a double field in the B_Rules table, "association_distance". This value will be used as a search tolerance for features that match the rule.
If this field does not exist, or the values are null, then a default of 5 units will be used.
Rows with a negative association_distance will be excluded from processing.
I added an issue to get this added to the web help.
Thanks for the tip - I searched high and low for this info on the Esri pages and didn't think to hit the little "?" within the tool parameters box.
