Coincident Lines - No Error
1267
09-01-2022 06:45 AM
G_Dillenger
I created duplicate line data by accident. The utility network did not pick it up. I thought the topology engine would know when coincident line data is here, similar to stacked points.
I recreated the example in the sample data above. Both features have the same terminals and subnetwork name. Pro 2.9.4, UN V5, FGDB
I found this odd since this was a problem we had in the geometric network. I'm hoping I'm doing something wrong. Is this expected?
Jens_Dalsgaard
What you report as an error could very well be a real-world scenario - parallel connections (overhead lines / cables) between two point in the network.
You'll likely have to do your own analysis to find line features with duplicate geometries.
Jens Dalsgaard
Principal Product Owner
Power Grid, V O L U E
jens.dalsgaard&@volue.com
Volue Technology Denmark A/S
Alfred Nobels Vej 27
9220 Aalborg Øst, Denmark
volue.com
G_Dillenger
I appreciate your response Jens. Perhaps so, but I would expect an offset if parallel. No worry of a loop condition here with a radial network? Not tested that yet.
G_Dillenger
I done more testing around coincident lines. What I found is that at the real world scenario you mentioned actually does not work in the utility network, as the subnetwork stops where coincident lines occurs. I was hoping that the utility network was going to help me finding these situations and mark it as an error.
Here is my example:
Highlight green is my subnetwork. I spread the lines apart for visualization, but the result is the same when coincident. My previous example had it at an place where it was supposed to stop.
A warning during subnetwork building would be greatly appreciated!
