When I run the Change Asset Package Spatial Reference tool, it completes successfully, but no output is created. The specified output GDB does not appear in the folder, and no data is written. Screenshots attached. I'm using the latest versions of both untools and utilscripts on my cloned conda env.
What troubleshooting steps would you recommend?
See below, no output package created. None can be found in the output folder specified either.
Can you try an output folder that is not One Drive?
Saving directly to my C drive also results in no output
Often a user's documents and download folders are actually configured for one drive.
Try another folder on the C drive. Something like C:\temp
I cannot repo the issue. What version of ArcGIS Pro and untools? Any messages in the GP tool log?
My untools version is below
Here is a text run straight to my C drive. The output is below.
No gdb created and nothing in the C drive folder
Other troubleshooting I've done:
A colleague shared their screen, and we noticed that the geodatabase name is not automatically populating when the Asset Package is selected from the file navigation. This has never populated during any of my attempts.
I noticed that ArcGIS Pro version 3.4 is a dependency for untools - do I need to update my ArcGIS Pro version from 3.3.2 to 3.4 for untools to work? My coworker is on version 3.3.0 despite this.
Please log a case with support for this issue.
This appears to be related to the active portal. The Solution was downloaded on AGOL and the active portal on ArcGIS Pro was Enterprise Portal. When the Solution was downloaded onto the Portal account and the tool was executed the auto-population works and output is attempted however the gp tool now outputs an ERROR 999999 instead related to domain not found for all domained attributes.
Parameters
Asset Package G:\TXH\Departments\Technology Solutions\Wilshin\UtilityNetwork\Water\Data Model\WaterEssentials_AssetPackage.gdb
Output Spatial Reference PROJCS["NAD_1983_StatePlane_Texas_South_Central_FIPS_4204_Feet",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",1968500.0],PARAMETER["False_Northing",13123333.33333333],PARAMETER["Central_Meridian",-99.0],PARAMETER["Standard_Parallel_1",28.38333333333333],PARAMETER["Standard_Parallel_2",30.28333333333333],PARAMETER["Latitude_Of_Origin",27.83333333333333],UNIT["Foot_US",0.3048006096012192]];-126725700 -77828800 3048.00609601219;-100000 10000;-100000 10000;3.28083333333333E-03;0.001;0.001;IsHighPrecision
Folder Location G:\TXH\Departments\Technology Solutions\Wilshin\UtilityNetwork\Water
Geodatabase Name COPY_WaterEssentials_AssetPackage
Output Package
Messages
Start Time: Tuesday, April 15, 2025 1:56:16 PM
ArcGIS Pro 3.3.2.52636
untools 3.3.3.1
Executing from ArcGIS Pro, 1 map(s), activeMap = True
Parallel processing enabled: 6
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
The domain was not found. [Water_Well_Diameter_Metric]
The domain was not found. [Water_Well_Diameter]
The domain was not found. [Water_Valve_Type]
The domain was not found. [Water_Service_Material]
The domain was not found. [Water_Service_Diameter_Metric]
The domain was not found. [Water_Service_Diameter]
The domain was not found. [Water_Meter_Diameter_Metric]
The domain was not found. [Water_Meter_Diameter]
The domain was not found. [Water_Main_Material]
The domain was not found. [Water_Main_Diameter_Metric]
The domain was not found. [Water_Main_Diameter]
The domain was not found. [Water_Hydrant_Service_Diameter_Metric]
The domain was not found. [Water_Hydrant_Service_Diameter]
The domain was not found. [Water_Fitting_Diameter_Metric]
The domain was not found. [Water_Fitting_Diameter]
The domain was not found. [Water_Diameter_Metric]
The domain was not found. [Water_Diameter]
The domain was not found. [Validation Status]
The domain was not found. [Pipeline_Valve_Status]
The domain was not found. [Pipeline_Casing_Diameter_Metric]
The domain was not found. [Pipeline_Casing_Diameter]
The domain was not found. [Operable_Status]
The domain was not found. [Network_6_UnknownAssetType]
The domain was not found. [Network_6_TierName]
The domain was not found. [Network_6_TerminalNames]
The domain was not found. [Network_6_IsSubnetworkController]
The domain is used as a default domain. [Network_6_IsDirty]
The domain was not found. [Network_6_IsConnected]
The domain was not found. [Network_6_FlowDirection]
The domain was not found. [Network_6_AssociationStatus]
The domain was not found. [Lifecycle_Status]
The domain was not found. [Lifecycle_Combined]
The domain was not found. [Construction_Status]
The domain was not found. [Asset_Type_Water_Line_Water_Main]
The domain was not found. [Asset_Type_Water_Line_Service]
The domain was not found. [Asset_Type_Water_Junction_Object_Service_Meter]
The domain was not found. [Asset_Type_Water_Junction_Object_Pump]
The domain was not found. [Asset_Type_Water_Junction_Fitting]
The domain was not found. [Asset_Type_Water_Device_Well]
The domain was not found. [Asset_Type_Water_Device_Treatment_Plant]
The domain was not found. [Asset_Type_Water_Device_System_Valve]
The domain was not found. [Asset_Type_Water_Device_System_Meter]
The domain was not found. [Asset_Type_Water_Device_Storage]
The domain was not found. [Asset_Type_Water_Device_Station]
The domain was not found. [Asset_Type_Water_Device_Service_Valve]
The domain was not found. [Asset_Type_Water_Device_Service_Connection]
The domain was not found. [Asset_Type_Water_Device_Sampling]
The domain was not found. [Asset_Type_Water_Device_Pressure_Valve]
The domain was not found. [Asset_Type_Water_Device_Interconnect]
The domain was not found. [Asset_Type_Water_Device_Intake]
The domain was not found. [Asset_Type_Water_Device_Hydrant]
The domain was not found. [Asset_Type_Water_Device_Flushing_and_Blow_Off]
The domain was not found. [Asset_Type_Water_Device_Flow_Valve]
The domain was not found. [Asset_Type_Structure_Line_Pipeline_Casing]
The domain was not found. [Asset_Type_Structure_Junction_Pipeline_Vault]
The domain was not found. [Asset_Type_Structure_Junction_Pipeline_Valve_Box]
The domain was not found. [AP_Traversability_Scope]
The domain was not found. [AP_Trace_Types]
The domain was not found. [AP_Topology_Types]
The domain was not found. [AP_Tier_Types]
The domain was not found. [AP_Terminal_Traversability]
The domain was not found. [AP_Terminals_Classes]
The domain was not found. [AP_Subnetwork_Types]
The domain was not found. [AP_Subnetwork_Propagation]
The domain was not found. [AP_Subnetwork_Operators]
The domain was not found. [AP_Subnetwork_Functions]
The domain was not found. [AP_Subnetwork_Filters]
The domain was not found. [AP_Subnetwork_EditModes]
The domain was not found. [AP_Subnetwork_Combinations]
The domain was not found. [AP_Rule_Types]
The domain was not found. [AP_Linear_Classes]
The domain was not found. [AP_Edge_Policy]
The domain was not found. [AP_Domain_Networks]
The domain was not found. [AP_Boolean]
The domain was not found. [AP_Attribute_Types]
The domain was not found. [AP_AttributeRule_Types]
The domain was not found. [AP_Association_Types]
The domain was not found. [AP_Association_Semantics]
The domain was not found. [AP_Association_Roles]
The domain was not found. [AP_Association_Classes]
The domain was not found. [AP_All_Classes]
Failed to execute (ImportXMLWorkspaceDocument).
Failed script Change Asset Package Spatial Reference...
Failed to execute (ChangeGDBSpatialReference).
Failed at Tuesday, April 15, 2025 1:58:33 PM (Elapsed Time: 2 minutes 16 seconds)
