Batch edit point layer z values to 0
1225
04-22-2025 09:40 AM
TanyaWright1
I want to batch edit the z values for all of my point layers in the utility network to be 0. I was able to do this for the line features using the solution from this post (https://community.esri.com/t5/arcgis-pro-questions/how-to-batch-edit-z-values-and-set-them-all-to/m-... ), but I can't figure out how to create the arcade to make this work for a point layer. Any suggestions?
Thank you!!
gis_KIWI4
MVP Regular Contributor
@TanyaWright1 - much simpler with a point. Use the "Calculate Field" option on the Shape Field.
Use the following arcade operation.
var geom = Geometry($feature)
var new_point = Point({
    x: geom.x,
    y: geom.y,
    z: 0,
    spatialReference: geom.spatialReference
return new_point
Tried it out on a test dataset, where z = 10
Hope this helps.
gis_KIWI4
    x: geom.x,
    y: geom.y,
    z: 0,
return new_point
Hope this helps.
TanyaWright1
@gis_KIWI4 thank you so much! This worked perfectly. Have a great day!
