automatically modify Association Containment
1539
11-18-2024 12:56 AM
abderhman97
I'm working with a large electric utility network data set I'm aiming to create an attribute rule or Python script that will automatically update the containment relationship between features in my utility network. Specifically, I want to ensure that each 'ElectricDevice' and 'ElectricLine' feature is correctly associated with its containing 'StructureBoundary' feature based on their spatial relationship
RobertKrisher
You should be able to find an example you can adapt in the attribute rule github repo: arcade-expressions/attribute-rules/attribute_rule_calculation at master · Esri/arcade-expressions · .... Something like the "Contain feature in a container within a search distance" would be a good place to start.
RobertKrisher
JohnGoat
Hello @RobertKrisher
I can automatically establish containment relationships with arcade codes. However, I have a large amount of data (2 million features). I trigger the arcade codes during data append. This process takes approximately 72 hours, I want to do this from the Oracle database, is this possible?
RobertKrisher
If you're trying to create many associations at the same time you should either handle this during migration by populating the C_Associations table using a relationship or using the Create Association Records tool to establish associations based on spatial proximity. If you are beyond the asset package, you can write a Python script to generate a CSV file you can import using the Import Associations tool.
Arcade was designed to work with small collections of features at a time, it does not effectively scale to thousands of features at a time.
