Assigned required user type extensions [Utility Network Service]
1922
11-03-2022 04:28 AM
GIS_Solutions
I have assigned the Utility Network extension to the creator user. I am logging into Field Maps with this user. Then when I try to edit, I get the following error. The user to whom I publish the web service and the user I log into Field Maps are the same user.
Also, when I click on the feature, the trace options (Named trace configurations) do not appear.
I am using ArcGIS Field Maps Beta program
Enterprise 11.0
do you have any ideas?@RobertKrisher
RobertKrisher
It sounds like it should work, but because this is beta software you may have found an issue with the beta. Please use the forums associated with the beta for this application to see if other users involved with the beta are experiencing the same problem and to let the team organizing the beta you are having an issue.
RobertKrisher
Spatial_Fabio
Does it work on a web map?
