Asset Package to Geodatabase Python Error
477
04-02-2026 10:23 AM
tobeykaneseitzGIS
Hi all - I am running into the following error when trying to run the asset package to geodatabase tool. I am using ArcGIS Pro 3.5 and it seems to be hitting a python error. I've copied the full error message (with file paths slightly adjusted) below
Asset Package To Geodatabase
Tool Path
Asset Package     \Transmission_Testing\March31\Test1.gdb
Service Territory Feature Class    \March31\Test1.gdb\UtilityNetwork\ServiceTerritory
Folder Location     ArcGISProTemp9260\Untitled
Geodatabase Name     Test1_UtilityNetwork
Feature Dataset Name     UtilityNetwork
Utility Network Name     Network
Domain Networks     Structure;Pipeline
Load data     SCHEMA_ONLY
Post Process     NO_POST_PROCESS
Configuration options
Rename using
Output Utility Network
Workspace Type     FGDB
Utility Network Version     COMPATIBLE
Messages
Start Time: Wednesday, April 1, 2026 2:14:23 PM
ArcGIS Pro 3.5.5.57366
untools 3.5.1
Executing from ArcGIS Pro, 0 map(s), activeMap = False
Parallel processing enabled: 48
Asset Package schema version: 3.5
A python error occurred.
EXCEPTION
  File "\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-2\Lib\site-packages\untools\common\wrappers.py", line 161, in wrapper
    f = func(*args, **kwargs)
  File "\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-2\Lib\site-packages\untools\gptools\tools.py", line 275, in run
    ap = ap_constructor(
  File "\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-2\Lib\site-packages\untools\gptools\tools.py", line 94, in ap_constructor
    ap = AssetPackage(
  File "\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-2\Lib\site-packages\untools\utility_network\ap.py", line 91, in __init__
    self._properties: dict = self._initialize(kwargs.pop("cache", None), **kwargs)
  File "CAppData\Local\ESRI\conda\envs\arcgispro-py3-clone-2\Lib\site-packages\untools\common\wrappers.py", line 434, in wrapper
    result = func(*args, **kwargs)
  File "\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-2\Lib\site-packages\untools\utility_network\ap.py", line 127, in _initialize
    data = self._validation.validate_all(asset_package=self)
  File "\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-2\Lib\site-packages\untools\validation\validate.py", line 1170, in validate_all
    klass(self).main()
  File "\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-2\Lib\site-packages\untools\common\wrappers.py", line 434, in wrapper
  File "\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-2\Lib\site-packages\untools\validation\schema.py", line 2901, in main
    self._validate_duplicate_existing()
  File "AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-2\Lib\site-packages\untools\validation\schema.py", line 2889, in _validate_duplicate_existing
    self._check_table_duplicates(groups)
  File "\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-2\Lib\site-packages\untools\validation\schema.py", line 2851, in _check_table_duplicates
    {(t.name.casefold(),): tuple(t.subtypes.names_lower) for t in tables},
  File "\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-2\Lib\site-packages\untools\validation\schema.py", line 2851, in <dictcomp>
  File "AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-2\Lib\site-packages\untools\describe\helper.py", line 197, in names_lower
    return [n.casefold() for n in self.names]
  File "\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-2\Lib\site-packages\untools\describe\helper.py", line 197, in <listcomp>
AttributeError: 'NoneType' object has no attribute 'casefold'
Failed script Asset Package To Geodatabase...
Failed to execute (AssetPackageToFileGeodatabase).
Failed at Wednesday, April 1, 2026 2:15:21 PM (Elapsed Time: 57.87 seconds)
MikeMillerGIS
Esri Frequent Contributor
Could I get a schema only copy of test1.gdb to see what is going on?
