Apply asset package to Structure Network feature classes
3039
9
05-20-2024 09:53 PM
rohanrajan_hms
I created a new utility network using "Stage Utility Network" tool, it creates a new dataset and a new utility network with Structure Network with it by default. When I use the "Apply asset package" tool, I want the schema of both Structure and Domain networks to be applied to the empty utility network. So, I check both the Domain networks in the list.
But I encounter this error.
ERROR 002580: The asset type domain is already assigned to another class or asset group.
What am I doing wrong?
Is there any way I can add apply asset package to my structure network without creating duplicates
ArcGIS Pro Version: 3.2.2
Asset Package : Water_Distribution_Utility_Network_FoundationV1_3, ElectricUtilityNetworkFoundationV2_2
Any help would be most appreciated
AnthonyRyanEQL
I would test this in ArcGIS Pro 3.1.x or 3.3 which are associated to the Long Term Supported versions of ArcGIS Enterprise
Announcing the 2024 Network Management Release Plan (esri.com)
rohanrajan_hms
Tried it with 3.1.x too. But it did not work.
Same set of errors
WARNING 000952: Failed to execute (AssignDomainToField).
MikeMillerGIS
Esri Frequent Contributor
Can you post more details.  Screen shots?  Did you modify the structure network at all after Stage?
rohanrajan_hms
Actually this happens when I am using the Apply Asset Package tool in a model that creates a GDB, stages a UN, Applies Asset Package in a sequence.
The Apply Asset Package tool worked fine when run separately "at some instances". Fails when I include the Structure Network in the domains.
These are the gp_calls log files of the Apply Asset Package tool I ran on same dataset (Water_Distribution_Utility_Network_FoundationV1_3) No changes made to asset package.
gp_calls_failed.log - Failed inside the model
gp_calls.log - Worked separately.
My problem is that it is inconsistent and fails even when run separately outside the model sometimes.
MikeMillerGIS
We have seen this when you run apply and have maps in a project.  Especially active maps.  There is a corruption that occurs.  We suggest running apply asset package in a pro project with no maps.
MikeMillerGIS
This is BUG-000157937 and was fixed in 3.3 btw.
rohanrajan_hms
I do run Apply Asset Package with all maps closed. Because it is explicitly mentioned in the tool document.  Even then it fails.
Anyway, Since it is a bug. I will have to move to 3.3. And the Asset Packages for UN7 are not available yet (If yes please direct me towards it).
Thank You.
MikeMillerGIS
Simply closing a map does not work, you need to close and restart pro.  Once a map is open, it is always open in that pro session.
You do not need a new asset package, just use the one you have on 3.3
rohanrajan_hms
Oh Okay. Thank You. But apparently, I would need Enterprise 11.3 as this suggests.
Solved: Re: Apply Asset Package on UnTools/Pro 3.3 require... - Esri Community
