Apply Asset Package doesn't append the data
1333
10
05-21-2026 04:55 AM
KokilaM
Hi Everyone,
The UN is building successfully in File Geodatabase with the Asset Package to Geodatabase tool , But When I apply the Asst package to SQL Enterprise Geodatabase , the tool succeeds but the data doesn't append to the featureclass/Tables .
When we try to manually run the append tool , Its failing with Schema difference error for the field match type of Schema must match , But If run the append tool with 'USe the Field map to match'option , there we dont find any differences the append tool succeeds
When we checked the logs for Apply AP- don't find anything related to append . Can you please share your view on this?
@RobertKrisher @MikeMillerGIS
KokilaM
Thank you Mike , It has resolved the issue .
