Adjusting Fitting/Device 3D Z-values and Maintaining Connectivity
600
06-27-2024 09:11 AM
MichaelParma
We are attempting to adjust z-values of fittings and devices in a more efficient manner. We are aware of the "Adjust 3D Z" tool. The issue is that if we run this tool on a selected set of fittings, the vertices on the mains and the corresponding lateral end points do not move with them to stay connected. However, if we manually select and edit the z-value on a single fitting or device, it does pull the vertex of the main or lateral.
I don't see a setting/toggle to enable or disable maintaining the connectivity. Our expectation is that it maintain the connectivity, but that does not appear to be the case for the tool.
What am I missing? Ideas for a workaround?
Mike
