Adding values in a Domain that is used in network attribute
1765
5
04-07-2025 12:49 PM
MatheusSparapani
If I want to add new values in a domain that is used in a network attribute? For example, I want to add abcn in phasesnormal attribute.
Do this in a assetpackage isn't a problem for me, because I'll start the migration yet.
Which path can I follow for this?
MikeMillerGIS
Esri Frequent Contributor
If the domain is not inline, should be no issue adding a new code, if the topology is disabled.  I would suggest using code 8, as the phase domain is based on bits.
Do you use propagation?  If so, only controllers can introduce bits, so ensure that the controller has the correct value with N.
gis_KIWI4
MVP Regular Contributor
@MatheusSparapani - Adding a domain is fairly simple and can be done during asset package stage or after deploying UN.
If you do it after the UN is live then you will need to stop services and add to the domain via a direct database connection.
MatheusSparapani
But, has a difference to add a domain in a network attributte? or is the same process to add in a normal attributte?
MikeMillerGIS
MatheusSparapani
Hi Mike,
How can I see if the domain is inline? I'm using the Essentials Model for Electric.
gis_KIWI4
You can check it under the Network Properties -> Attributes and Assignments
