Rename result of a trace function
1598
08-24-2022 08:50 PM
Status: Implemented
PierreloupDucroix
MVP Regular Contributor
Hello,
When performing a trace with a function (SUM, COUNT etc...) the result of this function is a summary that may not be really clear for the end user, ex :
It would be really helpful to rename each function, with a field "rename" at the end of each block.
The rename then would appear in the result of the tool, and accessible for further treatment in JS API.
Regards
Tags (3)
5 Comments
JonDeRose
PierreloupDucroix
Now that functions are available in Web Editor, I think it is even more important to show a clear alias for each one :
RichRuh
@PierreloupDucroix We've made the internal changes necessary to support this, and are beginning the work to roll this change out to web and mobile applications. Unfortunately, this was implemented too late to make it for Web Editor 12.1, but it should certainly make it for 12.3 (the next network management release)
--Rich
PierreloupDucroix
I just saw that this feature has been implemented in ArcGIS Pro version 3.7, thank you!
I'm looking forward to seeing it on the web and mobile versions as well!
Most importantly, it should be included in the JSON output of a named trace.
JonDeRose
Implemented with ArcGIS Pro 3.7 and ArcGIS Enterprise 12.1
Function name has been added as a property of the Functions parameter for Trace:
JonDeRose_0-1779203802893.pngJonDeRose_0-1779203802893.pngJonDeRose_3-1779204173370.pngJonDeRose_3-1779204173370.png
