Utility Network Package toolbox 3.3 release notes
5826
8
05-07-2024 04:03 PM
The 3.3 release of untools contains the fixes from untools 3.2.0. For more information, see the 3.2 release notes.
untools 3.3.4 - June 2025
  • Export Asset Package
    • Resolve BUG-000174483
  • Assign Terminal Connections
    • Flip logic when assigning terminals in sink based networks (see this post)
  • Apply Asset Package
    • Sync delimiters between CSV files and schema.ini
untools 3.3.3.1 - December 2024
  • Create Utility Network Associations
    • Restores behavior of GP tool broken with untools 3.3.3 (see this post)
untools 3.3.3 - November 2024
    • Resolve issue with the "Honor Digitized Direction" using the incorrect upstream and downstream terminal
    • Optimize and refactor code to scale on larger datasets
    • Resolve issue when using a D_Configuration table and applying a subset of domain networks
untools 3.3.2 - August 2024
    • Expose option (untools.common.settings) to run Compact. Previously this was always True, but now defaults to False.
    • Improve Rename table validation
      • Every row and column is now checked regardless if it is used.
      • Duplicates and length restrictions are now more consistently validated.
  • Miscellaneous
    • Resolve issues with various geoprocessings and input/output parameters from python.
untools 3.3.1 - July 2024
    • Support for Utility Network 6 & 7
    • Expose options (untools.common.settings) for custom precision/scale on single/double fields
    • Resolved issue where standalone tables would not be created in the target workspace
  • Stage Utility Network & Asset Package to Geodatabase
    • Add new parameter to choose the Utility Network version to create (6 or 7)
untools 3.3.0 - May 2024
  • Add support for Utility Network version 7
    • Big Integer network attributes
    • Flow Direction network attribute
    • Expose extent environment variable (in Asset Package to Geodatabase)
    • Skip tiers whose valid controllers are completely removed by D_Configurations table
    • Add support for terminal paths when there are 5 or more terminals
    • Skip feature classes removed by D_Configurations table
    • Support Data Reviewer attribute rules across tables
    • Improve support for Date network attributes
    • Validate contingent values on tables without subtypes
  • Upgrade Asset Package
    • Assign missing asset package domains to existing fields
  • Miscellaneous
    • Cleanup locks from arcpy cursors
    • Remove extraneous console logger
Comments
IvanDImitrov
Hi, Paul!
Thanks for the good news!
Did the team updated the annoying error, that 3.2.- give:
ArcGIS Pro 3.2.2.49743
untools 3.2.0
Executing from ArcGIS Pro, 0 map(s), activeMap = False
Parallel processing enabled: 6
C:\UN_V2_2\ZERO\AP_Workspace0\xml\ElectricLine_2_EditorTracking-AttributeRules.xml:255
ERROR 002717: Invalid Arcade expression, Arcade error: Table not found LineTypeLib, Script line: 1 [LineTypeLib]
WARNING 000952: Failed to execute (AddAttributeRule).
C:\UN_V2_2\ZERO\AP_Workspace0\xml\ElectricLine_2_EditorTracking-AttributeRules.xml:288
C:\UN_V2_2\ZERO\AP_Workspace0\xml\ElectricLine_2_EditorTracking-AttributeRules.xml:321
ERROR 002717: Invalid Arcade expression, Arcade error: Table not found LineTypeLib, Script line: 2 [LineTypeLib]
C:\UN_V2_2\ZERO\AP_Workspace0\xml\ElectricLine_2_EditorTracking-AttributeRules.xml:364
Failed script Apply Asset Package...
Failed to execute (AssetPackageToUtilityNetwork).
I think the XML is not correctly build here:
return new_id</expression>
            <triggering_events_insert>True</triggering_events_insert>
            <triggering_events_delete>False</triggering_events_delete>
            <triggering_events_update>True</triggering_events_update>
            <exclude_from_client_eval>True</exclude_from_client_eval>
            <is_editable>True</is_editable>
            <batch>False</batch>
        </AddAttributeRule>
    </workflow>
    <workflow>
        <AddAttributeRule>
            <rule_name>OperatingVoltage</rule_name>
            <rule_type>CALCULATION</rule_type>
            <rule_description>Fetch operating voltage</rule_description>
            <field_name>maxvoltage</field_name>
            <expression>var lookups = FeatureSetByName($datastore, 'LineTypeLib', ['*'], false);
No way the tool to recognise $datastore for a .gdb variant of the tool execution....
PaulLeBlanc1
@IvanDImitrovI am not aware of any issues in this area. This is valid arcade.
If there isn't a table called LineTypeLib then the runtime error is expected.
IvanDImitrov
@PaulLeBlanc1 Exactly!
The table is there - it is present and the name is correct (in the Asset Package).
Even this, the tool crashed
rlyding
@PaulLeBlanc1 I was hoping you could maybe answer a question on had on the Upgrade Asset Package Tool. I have a post in UN section I linked below. Trying to figure out when the upgrade tool would need to be run and what impact it has on the asset pack.
https://community.esri.com/t5/arcgis-utility-network-questions/question-on-upgrade-asset-package-too...
Thanks!
TomEriksen
New Explorer
Hi @PaulLeBlanc1 . I'm having issues using untools 3.3.3.1 to stage a utility network with the correct UN version. I'm trying to create a UNv6. Works fine when running inside of ArcGIS Pro, but when running as a standalone python script it creats a UNv7 even though the logging seems to be correct.
I have tested running StageUtilityNetwork as a GPtool, as a notebook and in the python window in ArcGIS Pro 3.3.5 wich results in the correct UN version. But as a standalone it always creates an UNv7.
TomEriksen_3-1741007502995.pngTomEriksen_4-1741007513472.pngTomEriksen_5-1741007521370.png
PaulLeBlanc1
@TomEriksencan you try from an non-elevated python command prompt? Internally, the tool is writing to the registry so that might explain it.
I am not sure what else could be the difference from in-app vs standalone python.
gpgisandsky
hi,
im on pro 3.3.5 + un tools 3.3.3.1. When I try to apply assetpackage to file geodb (empty un v7) the following error appears:
The issue is related to how the CSV was generated by the tool during execution (AP_Workspace0\csv\association001.csv). The tool creates a CSV file using a comma as the separator instead of a semicolon, which is what the import tool expects. Is there a parameter in PRO  "or elsewhere that can be changed?
PaulLeBlanc1
@gpgisandsky I've not been able to reproduce that behavior, but I believe it should be resolved with 3.3.4
Version history
Last update:
‎06-06-2025 08:22 AM
Updated by:
Contributors
