Re: Branch Version Sql Views - Utility Network
145
Sunday
PierreloupDucroix
Hi, @RobertKrisher can you elaborate a bit more on materialized views VS regular views ? I cannot find information about performance assessment or the use of views for data access.
Ex : I want to join rows in the electricJunctionObjects with their associated features so I can create a view that allows me to zoom to each object.
Should I create a standard or a materialized view with a JOIN, or create separate materialized views for electricJunctionObject and electricDevice first, then create a JOIN view against them ?
CEO of MAGIS
RobertKrisher
This thread is in response to this article: https://community.esri.com/t5/arcgis-utility-network-questions/re-branch-version-sql-views-utility-n...
Materialized views aren't available on all platforms, so in some cases, you would be writing the contents of the branch version analytics to a table for reporting purposes. For the sake of this comment, I'll just assume you're using a materialized view.
I would typically create a materialized view on the separate tables first. That way when I need to create a second or third report using any of those tables I can just use the tables I've already materialized.
Creating a materialized view that contains a join for those tables will probably take longer than materializing the tables separately, especially once you bring the associations table into the mix. If this is a one-off, and the performance is better this way, then go ahead. But as soon as you need to make a second or third materialized view you will likely find the approach outlined in the article will be more scalable.
PierreloupDucroix
Interesting! So the first step is to create materialized views for all the tables we'll use for analysis or export purposes, and to create a refresh function.
In addition to the join view, we need to create a view on the association table for exports, but based on your message, it would be more appropriate to also create a materialized view for this table and refresh it just before exporting.
Similarly, for visualization purposes (e.g., a dashboard with equipment symbolized by its last maintenance status), we could consider a standard view based on the materialized views of equipment and maintenance.
Thanks
CEO of MAGIS
RobertKrisher
That all seems reasonable.
