Adding Parcels - Geometry: Invalid
623
08-26-2021 09:06 AM
by Anonymous User
Not applicable
I am trying to upload my parcel layer but I run into the following error. There is 360,000 polygons within the layer. Is there a limit on the number of parcels?
jcarlson
You probably have invalid geometry is all. Try checking, and if applicable, repairing the geometry prior to uploading.
- Josh Carlson
Kendall County GIS
Till_Schmid
Hi @Anonymous User
You could also check if there are parcel features without geometry (empty geometry) in your dataset. This will throw the same error.
ArcGIS Urban doesn't have a limit regarding the number of parcels you can upload. Just be aware that a huge number of parcels can reduce performance, especially inside plans.
MaximeDemers
For what I experienced, first, parcels must be in wkid:3857 without curves in the geometry. Also, there should not have identicals parcels overlapping and multiparts are suggested to be desagregated in single parts.
