Learn ArcGIS Question
2205
7
02-12-2020 07:38 AM
DEAF_PROBERT_68
Honored Contributor
I worked on Learn ArcGIS's  Georeference  in ArcGIS Pro and I found some issues on that one....
Georeference Imagery in ArcGIS Pro | Learn ArcGIS
I see there is no comments at the end of the lesson and it would be Nice if they inset it if there are any issues or problems...
I found some issues on that lesson and i spend some time to solve the problem on my own part.
Is there a way for me to make my comments or suggest to it ?
I want to add another one... It needs to put down what version they wrote that lesson down... It helps us to know which version that works or not...
DanPatterson_Retired
Robert
Way, way way down on the bottom right is a link for all learning materials.
Send them your commentary there
Feedback | Learn ArcGIS
HeatherSmith
Hi Robert,
Thanks for your feedback! Commenting/questioning and software version are both things we are hoping to address in the future.
For now, the best way to pose questions or provide feedback about a lesson is right here, on the Learn ArcGIS GeoNet space, or through a private email, which you can send via this form: https://learn.arcgis.com/feedback/
The lesson Georeference Imagery in ArcGIS Pro was written for ArcGIS Pro 2.5.
I'm glad you were able to solve the problem on your own. We'd still like to hear about the issue (and your solution!) so we can prevent it for people doing this lesson in the future.
Thanks!
Heather
Heather Smith‌ our link to the form is the same...
also... to shorcut posting a suggestion there, perhaps they could make the font much larger and maybe duplicate at the top of the page as well
DEAF_PROBERT_68
Honored Contributor
Thank you you all !
Will do when I get a chance to write down tonight...
DEAF_PROBERT_68
Honored Contributor
Sorry ...
Here is the link .
Just go to Control Points section ...
Heather Smith ‌Dan Patterson
There you go...  I convert the website to pdf then convert to MS Word.
I  typed it in text box with yellow highlight...
I have not done any compare transformation methods so I have not check on them yet...  I will go back and try them when I have a time.
Have a good day.
HeatherSmith
Thanks Robert!
This looks like something that we can easily fix in the lesson for our next update. I'll send it on to the author. Thanks very much for taking the time to report it to us!
Heather
DEAF_PROBERT_68
Honored Contributor
Sure no problem !
