How to draw dynamic rectangle to clip raster using Arcpy
813
02-14-2021 11:52 PM
ShalineeeMishra
We have a raster image and need to clip a part of the image based on a dynamic rectangle. The rectangle is formed when user mouse to click anywhere in the image then a rectangle will be created dynamically with certain height and width.
Thanks in advance for your help
DavidPike
MVP Notable Contributor
If you supply a feature set as the get parameter FeatureSet—ArcGIS Pro | Documentation you can create a feature which is then passed to the tool
