ArcGIS Survey 123 Connect Error
1708
03-17-2021 10:27 AM
DEAF_PROBERT_68
Honored Contributor
Would anyone tell me why I get the error here ?
This is from the Learning ArcGIS Dashboard and here it is https://learn.arcgis.com/en/projects/collect-hurricane-damage-assessments/
Scroll down to Create and test surveys for data collection  then
go to modify the new survey
DEAF_PROBERT_68
Honored Contributor
Never mind ! I took care of it right before you answered.  I think it is because I copied and paste to the bottom of the Excel is what caused the error.
I play it around and test by delete the copied and paste. It worked.
HeatherSmith
Esri Alum
Hi @DEAF_PROBERT_68 you can click OK on that error dialog. See the step immediately before the Modify the new survey section:
DEAF_PROBERT_68
Honored Contributor
DEAF_PROBERT_68
Honored Contributor
To be honest , sometimes it can be unclear on that exercise ! It takes a time to figure it out ...BTW
DEAF_PROBERT_68
Honored Contributor
Another problem I am having is
How do I fix it ?
