XLSForm warning pop-up
1289
03-31-2022 09:33 AM
ParksBrian
When I open the XLSForm for my survey, a warning pops up (below). I circled the "invalid data" and it identifies all of the 'select' fields. I can still publish the survey but when I identify who has permission to submit surveys ("Everyone" or a group of members), it keeps deleting my selection and leaves it blank so that they my colleagues can't submit data. They get a message that says "getting service information". I'm not sure if this warning is causing other problems.
XLSForm WarningXLSForm WarningInvalid data circledInvalid data circled
DeonLengton
Hi Brian
Can you share the actual XLSX file? It could be a reserved keyword or something that is causing it, but could also be something in your choicelist - hard to tell without the excel file.
ParksBrian
Hi Deon,
Here is the excel file. I can't think of any external link it would be warning me about. I thought this survey was pretty straightforward like the other surveys I've built. It's the first time I've had this warning pop up.
Brian
ParksBrian
