XLSForm Conversion Failed
4169
7
03-24-2022 10:17 PM
JuanDuran
I have been working with Survey123 creating an XLS Form. Everything was fine until I think I use too many choices. I have to use the same questions for a lot of variables in my survey: I would have the owner of the pole, and the owner of the anchor and the owner of the wires and so on. The question is: can I use the same choice list in all of the questions?
I have
select_one poleownerpole_owner
and the choices are:
list_namenamelabel
poleownertelusTELUS
poleownerjointJOINT
poleownerbchydroBC HYDRO
poleownerunknUNKNOWN
when I am in other question, I need to know the owner of the anchor
select_one anchorowner
anchor_owner
Do I have to use another choice list like this?
anchorownertelusTELUS
anchorownerjointJOINT
anchorownerbchydroBC HYDRO
anchorownerunknUNKNOWN
anchorownerpolePOLE
Or can I use the same variable (type and name) and only one list of choices for all the times I need the owner?
something like: select_one owner with the name owner and with a list of choices just owner and the options?
I am asking this because I am getting this XLSForm Conversion Failed error because I think I have too many choices ....it is a long form and I have this questions and others repeated over and over and I have created a long list of choices.
Tags (3)
JuanDuran
No, it is not the long list of choices.
I cut the whole form to the first group and I am still having that issue. Please help.
Here is the first group and some few choices and I am having the same message.
IsmaelChivite
Esri Notable Contributor
Hi.The XLSForm validation service is not returning XLSForm syntax error descriptions. I created an internal note to point this out.
You should be able to reuse lists across multiple questions. Pleas wait until the validation service problem is addressed. Without proper error messages is very difficult to design a form. In line 5 your question references a missing list in the choices list. Lines 40 and 41 also cause trouble, but I have not been able to figure out what's wrong with them.
LeonardBarnhill
My comment on reuse is almost moot after Ismael's response but I will agree and confirm that you can reuse items in the choice list for different questions.  I do it repeatedly with yes_no, name lists, and condition assessment questions.
As to the error message with no details about XLSForm conversion, I get the same message and have been unable to determine the cause.
JeffreySteele
I received the error XLSForm conversion failed! this morning, when trying to make a survey from a feature class. my other surveys work fine and I can update them. It only happens on new surveys. I still receive the excel data, very strange. Am I doing something wrong or is it the program itself? Thank you for your time.
JeffreySteele
Thank You! I missed that post.
IsmaelChivite
The fix is now in production. Thanks for your patience.
