Will a Javascript function work in a survey shared through Hub Premium?
1308
10-13-2021 10:36 AM
Jordi-Monk-Developer
One of the limitations of using JavaScript functions within a Survey123 survey is that "signed users must be members of the same organization as the survey's author".
We are planning on giving access to our survey to members of a Hub Premium's Initiative.
Will the JS function work or not?
ZacharySutherby
Hello @Jordi-Monk-Developer
If the members of your Hub Premium Initiative are members of your ArcGIS Hub team they will be users in your ArcGIS organization. You will just need to make sure that they have to correct user type and role and are licensed with the Field Apps license bundle so they can use Survey123.
Please check out the user types, roles, and privileges documentation for more information.
Thank you,
Zach
ZacharySutherby
Thank you,
Zach
